Will Ford 460 Billet HEI Distributor fit a 390 FE?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2007, 05:08 PM
texastomeh's Avatar
Need a little help from you Ford experts!
Will a Ford 351C/460 Billet HEI Distributor fit (or be made fit) and work (or be made to work) on a 1963 Ford 390 FE?
When I ask; "..be made to fit/work?" - I'm referring to something like a minor change to clear an interference, change the drive gear or some relatively simple wiring.
thanx,
texastomeh
Old 06-27-2007, 02:55 PM
call autozone
call a reliable parts house and see if they swap out to the same
just get them to pull up parts number to see if they match
Old 07-06-2007, 08:11 PM
I am no expert but I do know this...the 390 is a different engine family from the 460. The 390 is an FE motor in the same family as the 360, 427 and 428 (and I think the 352). Ask the manufacturer and you might find that they are interchangeable.
Old 07-08-2007, 07:43 AM
aka Duke of URL
No........
Old 07-09-2007, 07:52 AM
texastomeh's Avatar
Thanx KULTULZ!
THAT is the definitive answer that I was looking for! It is not the ONE that I wanted, but at least now I believe that I know for certain.
It is not that I don't appreciate you other guys' recommendations, but that was the very problem - I got different answers from different parts guys!
texastomeh
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
Ford HEI / MSD 6AL mr.Pinto Electrical 5 04-10-2007 08:07 PM
Issue with Ford 460 clutch onebadmerc Transmission - Rearend 1 02-22-2007 06:15 PM
Ford 390 FE Motor mounts chadzeilenga Engine 1 08-18-2004 03:16 AM
Ford 390 rebuild...What's the best year?? Bo_Jangles Engine 3 03-01-2002 04:02 PM
