Will higher octane help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2013, 04:42 PM
I'm running 91 octane (thats the highest we have) for my 406, It has 210 cranking pressure
& the compression is 10.4.
Will it benefit with higher octane or even a 50/50 mix of 110/91??
The timing is set at 35-36*
Old 02-16-2013, 07:52 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
With a 10+:1 c.r., sure. Higher octane is always a plus in a performance oriented non-computer controlled n/a motor.
Semper Fi
Old 02-16-2013, 08:42 PM
vinniekq2's Avatar
g
[QUOTE=68NovaSS;1647224]With a 10+"1 c.r., sure. Higher octane is always a plus in a performance oriented non-computer controlled n/a motor.[/QUOTagree]
agree
Old 02-17-2013, 06:53 AM
what heads?
what cam?
what gear, trans, car weight?
is it detonating now?
higher reving v8 nate4567 Engine 55 04-01-2009 09:21 PM
Missing at higher rpm's byby50 Hotrodding Basics 4 10-25-2006 08:48 PM
higher-octane? Pontiacman Introduce Yourself 3 01-07-2006 06:48 PM
93 Octane / 110 Octane fatrat96 Engine 4 12-29-2004 02:09 PM
Rafters need to be raised higher... Cliff Elikofer Garage - Tools 21 06-04-2004 05:48 PM
