Will Hot Cam 1.6 rockers fit under Vortec valve covers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2010, 08:18 PM
I'm building a vortec head based 350 roller block and haven't picked up any valve covers yet. I am using the 1.6 ratio roller rockers that come with the GM Hot Cam Kit. I like the stock stamped steel center-bolt valve covers and would like to use them if possible. Have any of you guys fit these rockers under the Chevy valve covers?
Old 01-20-2010, 08:35 PM
dklong's Avatar
are they full roller rockers, if they are , they won't have the clearence, GM use to make a adapter to convert center bolt vavle covers heads to the old style 4 bolt valve covers (check with the GM performance parts book)
Old 01-20-2010, 08:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
They fit under the covers of the crate engines GM sells that use that rocker.
Old 01-21-2010, 12:40 PM
The GM 1.6 roller rocker is a Crane design, it will fit under GM center-bolt covers. Other roller rockers either in brand or different models of Crane may have interference issues with the center bolts. You may grind and polish a clearance as necessary or convert to perimeter bolts with the purchase of adapters which are expensive or the fabrication of same if you have some tools and talent (saber saw, files, electric drill in case your shop is missing a milling machine, and a tap set will work fine) for a lot less money if you can find some quarter inch aluminum plate.
Bogie
Old 01-21-2010, 02:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Extra thick and/or double gasketing can get you extra height as well.
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
Howards Cams Greg T Engine 21 10-04-2009 12:28 PM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
after market valve covers Kevin64 Engine 7 06-22-2003 01:56 PM
after market valve covers Kevin64 Engine 0 06-21-2003 08:09 PM
