Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - will this howard cam work for my combo?
Old 06-21-2011, 12:27 AM
chevyrally68 chevyrally68 is offline
68 chevelle malibu
327 .40 over
670 holley vac secondaries
hooker headers
hei distributor
cast iron 68 heads gm with 2.02's ported and polished and deshrouding
stock 10 bolt highway gears I assuming, not sure on gearing
th350 trans with a 2000 stall converter
245 60 r 15 front tires
275 70 r15 rear tires
spin tech mufflers
edelbrocke rpm intake
Will this camshaft work for my combination, I would like something with some good low end torque and a nice slight lopey sound, good idle quality with a good vaccum for brake booster for disc brakes.
Howards, Camshaft, Chev SB, Hydraulic Flat Tappet,
Chev SB
Application: Max Factory
RPM Range: 2000-5600
Lift: .447/.447
Adv. Duration: 290/290
Duration @ .050": 223/223
Lobe Sep. Angle: 112
Recommended Valve Springs: 98214
Nice idle, near duplicate of Chev 325HP/327 cam (GM #3863151)
