will this howard cam work for my combo?
68 chevelle malibu
327 .40 over 670 holley vac secondaries hooker headers hei distributor cast iron 68 heads gm with 2.02's ported and polished and deshrouding stock 10 bolt highway gears I assuming, not sure on gearing th350 trans with a 2000 stall converter 245 60 r 15 front tires 275 70 r15 rear tires spin tech mufflers edelbrocke rpm intake Will this camshaft work for my combination, I would like something with some good low end torque and a nice slight lopey sound, good idle quality with a good vaccum for brake booster for disc brakes. Howards, Camshaft, Chev SB, Hydraulic Flat Tappet, Chev SB Application: Max Factory RPM Range: 2000-5600 Lift: .447/.447 Adv. Duration: 290/290 Duration @ .050": 223/223 Lobe Sep. Angle: 112 Recommended Valve Springs: 98214 Nice idle, near duplicate of Chev 325HP/327 cam (GM #3863151) |
or what would you guys recommend for this set up???
The cam will work fine for your purposes. The only thing I see wrong is you don`t know the gearing, the rear gears will dictate how your combo performs. If you gave it some 3.50:1 gears It would work nicely.
Make sure you match the valve springs to the cam. I wouldn`t use this cam, but that`s just me, but it will work for what you want to do. |
what would you use double vision if this was your set up?
Even so I don`t like to pick cams for others as I`m conservative, I will say that cams today such as the voodoo and extreme energy grinds are far better than the grinds of old. This cam I found on Lunati`s site in the Voodoo line looks good.
http://www.lunatipower.com/Product.aspx?id=1984&gid=287 |
Thanks double vision, this cam does look good for my application. wonder how the idle quality is? and the vaccum for booster? maybe i will call tomorrow and talk with a tech at lunati, thanks again
It should have a fairly choppy idle. I`m sure it should have plenty enough vacuum for power brakes. However, contacting Lunati and asking is a good idea. Just call me DV, it`s easier.
For "Hiway gears" and a 2000 stall find a cam with 208 to 218 @.050 duration.
The cam you are looking at wants a bit of a converter and some gear to work best . Up to a 3000 stall and 4.10's for strong street performance. For the gears and converter you got you'd be better off with a bit smaller duration cam. Like a Comp dual energy 265DEH-10 or similar. 211in -221ex @.050 .442-.465 110 LSA. Lunati and Howard have similar cams. |
You cannot have a rough idle and good vacuum, pick one.
you can use manual brakes or hydro-assist if you don't have enough vacuum. Most engines I build end up requiring that- its no big deal. |
| All times are GMT -6. The time now is 05:45 AM. |
