will this howard cam work for my combo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2011, 12:27 AM
68 chevelle malibu
327 .40 over
670 holley vac secondaries
hooker headers
hei distributor
cast iron 68 heads gm with 2.02's ported and polished and deshrouding
stock 10 bolt highway gears I assuming, not sure on gearing
th350 trans with a 2000 stall converter
245 60 r 15 front tires
275 70 r15 rear tires
spin tech mufflers
edelbrocke rpm intake
Will this camshaft work for my combination, I would like something with some good low end torque and a nice slight lopey sound, good idle quality with a good vaccum for brake booster for disc brakes.
Howards, Camshaft, Chev SB, Hydraulic Flat Tappet,
Chev SB
Application: Max Factory
RPM Range: 2000-5600
Lift: .447/.447
Adv. Duration: 290/290
Duration @ .050": 223/223
Lobe Sep. Angle: 112
Recommended Valve Springs: 98214
Nice idle, near duplicate of Chev 325HP/327 cam (GM #3863151)
Old 06-21-2011, 01:11 AM
or what would you guys recommend for this set up???
Old 06-21-2011, 01:14 AM
DoubleVision's Avatar
The cam will work fine for your purposes. The only thing I see wrong is you don`t know the gearing, the rear gears will dictate how your combo performs. If you gave it some 3.50:1 gears It would work nicely.
Make sure you match the valve springs to the cam.
I wouldn`t use this cam, but that`s just me, but it will work for what you want to do.
Old 06-21-2011, 01:16 AM
what would you use double vision if this was your set up?
Old 06-21-2011, 01:37 AM
Even so I don`t like to pick cams for others as I`m conservative, I will say that cams today such as the voodoo and extreme energy grinds are far better than the grinds of old. This cam I found on Lunati`s site in the Voodoo line looks good.
http://www.lunatipower.com/Product.aspx?id=1984&gid=287
Old 06-21-2011, 02:30 AM
Thanks double vision, this cam does look good for my application. wonder how the idle quality is? and the vaccum for booster? maybe i will call tomorrow and talk with a tech at lunati, thanks again
Old 06-21-2011, 02:48 AM
It should have a fairly choppy idle. I`m sure it should have plenty enough vacuum for power brakes. However, contacting Lunati and asking is a good idea. Just call me DV, it`s easier.
Old 06-21-2011, 06:31 AM
Banned
You cannot have a rough idle and good vacuum, pick one.
you can use manual brakes or hydro-assist if you don't have enough vacuum. Most engines I build end up requiring that- its no big deal.
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
my name is terrence howard terrence howard Engine 2 10-18-2007 06:29 PM
Howard Stern Last Day 1931 steve Off-Topic 18 12-18-2005 12:17 AM
For JB Howard on the '46 Panel Bluepen Hotrodders' Lounge 0 04-28-2004 08:43 PM
will this combo work??? mikeweyman Engine 4 01-08-2003 11:00 AM
