Will this hurt my newly rebuilt 2004R? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2014, 11:39 AM
56don's Avatar
Senescent
I just rebuilt my engine and need to break in the cam. I also have a newly rebuilt 2004R behind it that I just installed. Will it hurt the transmission if I run the engine at 2000rpm for 20 minutes while the trans is in park? I have heard different stories about these transmissions being critical on initial use. I have about 2 quarts of fluid in the converter already and will put more in the trans but I think it may pump dry while the engine is breaking in.
Advise please.
Old 07-18-2014, 11:43 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
trans must be full of oil during operation.
Would you run an engine low on oil? Same principle
Old 07-18-2014, 12:02 PM
56don's Avatar
Senescent
I know very little about automatics. So even if the trans is in park then the pump is pumping oil throughout the transmission?
How many quarts would you think a 2004r would take if its completely dry except a couple of quarts in the converter?
Old 07-18-2014, 12:11 PM
Burnt out transmission tech.
Simply fire up the engine and add transmission fluid.
Doesn't seem that difficult.
Old 07-18-2014, 01:31 PM
The mobile view is crap
You could install a psi gauge on the transmission line to keep an eye on things. If the gauge pressure gets to low start pouring in fluid. Have a funnel in the dipstick ready to go.
Old 07-18-2014, 02:26 PM
T-bucket23's Avatar
Wiki Edits: 26
Holds 11 qts from dry. I would put in 4 or 5, start it and put in 5 more. Someone helping with either keeping the rpms up or filling the transmission would be helpful. You already have 2 in the converter so deduct that from the 11 total.
Chet
Old 07-18-2014, 04:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The engine spins the converter.
The converter spins the pump on the transmittin.
When the transmittin has little oil, the pump is running metal to metal. This Burns the pump up, also damages the converter.
A few hundred $$ in repairs
Old 07-19-2014, 10:07 AM
Banned
this...
you should always have a few buddies around.. anyways..
it helps find leaks, watch oil psi, water temp.. and grab a fire ex. if needed..
Old 07-19-2014, 10:18 AM
good tranny pick. I prefer that over the 700 r4. Their right, tranny has to have lubrication. Run it in every gear for a second or two to get it in every were. Then check fluid level. Make sure to check it several times.
The Following User Says Thank You to dwwl For This Useful Post:
PapaG (07-23-2014)
Old 07-19-2014, 10:41 AM
Originally Posted by gearheadslife View Post
this...
Gotta have somebody to open beers.
Old 07-19-2014, 05:25 PM
56don's Avatar
Senescent
Unfortunately, I don't have any buddies, I have to open my own beers. But then I get to drink them all too.... ☺
Old 07-20-2014, 09:46 AM
81 Vette
I did a new engine and 2004r install a few years back. Trans and converter holds 11 quarts. I think I poured 3 or 4 into the converter and stabbed it on to the trans then attached to engine. Once installed put another 5 quarts in the trans. On first start up I just got the new engine to idle at around 1200 rpm. Checked timing and add trans fluid till it showed on the dip stick. This didnt take more than a few minutes. Shut the engine off and checked for leaks and such. Then went with the cam manufacture break in spec. No problems with the trans or the engine. Hope you have good luck with the new power plant
Old 07-20-2014, 10:52 AM
You didn't go with the cam manufacturer break in spec if you were at 1200rpms for a couple minutes on initial startup.
Old 07-20-2014, 11:06 AM
I take it that the O.P.'s concern is not wanting to idle a new engine during break-in while checking and filling the trans. There is a VERY easy solution to this. Unbolt the converter from the flexplate and push it back into the bellhousing. Break in the engine. Reassemble, then worry about the trans. Note that you should have the rear wheels off the ground when you are checking and filling a newly rebuilt trans.
The Following User Says Thank You to joe_padavano For This Useful Post:
PapaG (07-23-2014)
Old 07-20-2014, 03:23 PM
56don's Avatar
Senescent
This is what I did. Thanks
newly rebuilt 700R4, only first and reverse! GMC9595 Transmission - Rearend 12 10-28-2013 01:52 AM
Newly Rebuilt 200 4R Start up Question mrpate Transmission - Rearend 6 05-04-2012 02:25 AM
newly rebuilt quadrajet problem dawg Engine 2 08-27-2009 04:41 AM
Newly Rebuilt SBC 283 Wadeamca Engine 8 03-13-2009 07:53 AM
Newly rebuilt 327 shudders & other ??'s dirtslingerrc Engine 9 09-06-2006 10:21 PM
