Will I have any issues? 327 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2012, 07:32 PM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
I have a 327 sbc in my Impala. As you can see in the picture, there is some damage. The piston took most of the damage and I am going to replace it. If I install a brand new piston and rings, will I have any issues with the amount of damage in the picture or no? Thanks
Old 08-18-2012, 07:37 PM
Looks pretty bad to me. If this is the '65 Impala convertable it needs to be NICE. I love those old cars.
Old 08-18-2012, 07:39 PM
Last journal entry: Still running strong
Kind of hard to see but I would think the fire ring on a head gasket wouldnt seal.Deck it.
Old 08-18-2012, 08:21 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
It looks like the whole piston bore is hammered, at least that's what my old eyes see. If it is, a new piston is a waste of money. That hole needs to be sleeved.
Old 08-18-2012, 08:41 PM
I have had a couple people look at it and say that its ok but I just wanted to double check. It is the original engine for the car.
Old 08-18-2012, 09:13 PM
vinniekq2's Avatar
taken any measurements yet?
Old 08-18-2012, 09:20 PM
Im sorry. Measurents of what?
Old 08-18-2012, 09:23 PM
Here is another picture.
Old 08-18-2012, 09:33 PM
Maybe I don't really understand your question. A machine shop can fix it, but it's going to take more than just a hone and rings. I think you'll probably need to sleeve it. Good luck, Bill.
Old 08-18-2012, 10:08 PM
327NUT's Avatar
I concur, there's no way in the world you could run that cylinder without boring and honing IF you also did the other 7, can't run different size pistons due to a balance problem. I would think...as earlier said the easiest and cheapest way is to sleeve it. Also all the schrapnel from the piston and cylinder is probably all through your oil passages and bearings, time to tear the whole sheeeebang apart for a good hot tank and jet clean.
Basically I wanted to know if I will have any issues if I install a new piston and rings with the engine in this condition?
Old 08-18-2012, 10:11 PM
327NUT's Avatar
You would have major issues, don't even think about it.
Old 08-18-2012, 11:11 PM
It will not do any good just replacing the piston and rings. The block has too much damage. If you did do it that way chances are the top ring would hit the damaged area and break. Also I doubt whether you would have any compression on that cylinder. The head gasket might not also seal around the edge of the chamber. If not many miles on the engine just have that cylinder sleeved and install new piston and rings. vinniekg2 was referring to taking measurements to see how much the cylinder would have to be bored to clean up the damage.
Old 08-19-2012, 06:15 AM
Ok thanks for your help
Old 08-19-2012, 08:00 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
You are going to have to bore, hone, and sleeve it. Maybe even deck the block. Then bore and hone all the rest of the cylinders to match. By the time you get done with that I bet you can find a used block much cheaper on Craigs List. Unless you have to have the original block with the car.
350 sbc issues Dirtdolla Engine 2 05-03-2012 07:48 PM
rebuilt 327 issues 4lug39 Engine 5 07-10-2010 08:36 PM
1965 impala 327 starting issues. rally4sport Engine 1 04-23-2010 12:24 PM
Freshening old 327 - deck height issues weedy64 Engine 35 10-17-2009 02:26 AM
SBC engine issues HELP viperjesse Engine 15 02-15-2005 05:27 AM
