Will I reduce the vacuum? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2009, 01:11 PM
redride's Avatar
1969 Nova SS502
My current set up is a 502 with a BMT roller cam ground on 107, big lope and small on vacuum. I am runnng a vacuum can to my 7" brake booster. I am also running braded line from both breather caps and it is connected to the header collectors. My question is if I remove the lines from the header collectors to the breather caps and replace this with a pcv valve to the carb on one side and just a breather cap on the other will I reduce the amount of vacuum gong to my vacuum can? I do not like the huge braded lines going to the breather caps and want to do away with this but I need the vacuum for my brakes.
Old 05-16-2009, 01:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't see that as being a problem- to plump a PVC instead of the exhaust set-up.
The set-up as-is, should only be drawing down the crank case, and should not affect the vacuum in the intake tract to any appreciable degree.
The PCV valve does draw off a little vacuum signal, but IMHO, not enough to alter how the vacuum can works now.
Old 05-16-2009, 05:30 PM
redride's Avatar
1969 Nova SS502
Ok, thanks
Old 05-16-2009, 06:28 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You really shouldnt even notice IMO. Cole
Old 05-16-2009, 07:23 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
agreed that will work fine and look a heck of a lot cleaner . they make breathers with the pcv hidden inside .
http://store.summitracing.com/partde...5&autoview=sku
Old 05-16-2009, 07:25 PM
redride's Avatar
1969 Nova SS502
Yep that is one reason I want to change it.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
detonation 71 chevy c-10 Engine 33 04-29-2010 12:20 PM
How much is too much advance Mertz Engine 33 04-26-2008 11:11 AM
Chevy 454 PCV and Vacuum question rakundig Engine 7 10-29-2003 08:33 PM
69' Camaro RS Vacuum Hide-away Headlights PrimaDude Engine 1 11-18-2002 12:46 AM
