Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will a intake off vortec heads fit non-vortec heads
Old 12-26-2010, 09:52 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by bondo
Ayuh,... Not to argue, but that's just plain ole Wrong....
The Intake ports are .200" Higher on Vortec heads, 'n the intake ports are Also....
Maybe you see it that way, but the water ports and intake ports are in the same basic location they have been in since 1955. Might be a little taller, wider, whatever, but if the gasket is big enough it will cover and seal. It is the bolt holes location, angle and number used that are majorly different and the thing that prevents swapping Vortec intakes for conventional intake.
The Following User Says Thank You to ericnova72 For This Useful Post:
blavila11 (06-16-2014)
