-   -   Will K Member From '65 Dart Fit '72 Duster (http://www.hotrodders.com/forum/will-k-member-65-dart-fit-72-duster-86900.html)
STATUTORY GRAPE 04-14-2006 08:38 PM
Will a V-8 K-member from a 1965 Dart fit a 1972 Duster?
Good Frosty 04-15-2006 12:21 AM
I'm pretty sure there is a little bit of difference in them...or you could go to the forums at this place....www.allpar.com
-GF
onebadmerc 04-15-2006 08:04 AM
The the K member is different on the earlier A Bodies, Dodge changed the K members in 1967. The K members from 67 and up should work, but in 1973 Dodge changed them again. The 73 and later have a different sway bar mount and use the stronger motor mounts. The 73 and later A Body K member will also work on any A Body from 67 and up but has these differences.
