Will K Member From '65 Dart Fit '72 Duster - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2006, 08:38 PM
Will a V-8 K-member from a 1965 Dart fit a 1972 Duster?
Old 04-15-2006, 12:21 AM
User
I'm pretty sure there is a little bit of difference in them...or you could go to the forums at this place....www.allpar.com
-GF
Old 04-15-2006, 08:04 AM
onebadmerc's Avatar
I need a bucket of arc sparks
The the K member is different on the earlier A Bodies, Dodge changed the K members in 1967. The K members from 67 and up should work, but in 1973 Dodge changed them again. The 73 and later have a different sway bar mount and use the stronger motor mounts. The 73 and later A Body K member will also work on any A Body from 67 and up but has these differences.
will 72' Firebird front disc brakes Fit? hogggster Suspension - Brakes - Steering 7 02-16-2007 12:21 AM
are there any good sites for a 72 dodge dart 82c10 Engine 8 09-29-2005 12:12 PM
72 dodge dart transmission question A/G WILLYS Transmission - Rearend 4 05-08-2005 01:04 PM
What other cars would my 72 Cutlass seats fit in? elukas Interior 4 01-06-2004 10:33 PM
will the rear end out of a '65 chevelle fit a '72 Snatch Transmission - Rearend 3 03-02-2003 05:15 PM
