Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will lack of quench cause problems with this SBC build?
Old 04-02-2012, 02:19 PM
ap72 ap72 is offline
Banned
Originally Posted by Larry123
Thanks all, some answers to the questions: Yes I believe I have rebuilder pistons with stock deck height, deck clearance confirmed at .043. I did mis- state the DCR with the 64cc alum heads and .041 head gaskets I calc SCR = 9.3, DCR = 8.08, Quench = .084. Bogie may have the best (least cost solution) using 67cc vortec heads and .015 gasket with the same Lunati 60102 cam I get SCR = 9.5, DCR = 8.29, Quench = .058. I have not purchased heads or cam yet, I do have an old 64 vette 350 hp 327 alum manifold i was thinking of using, if i go with the vortec i will buy performer air gap. This is a street car and I will need to run pump gas, do you think the .058 quench will work ok with the vortec's at 8,29 DCR?
You can run just about any 64cc head and be fine with a .015" gasket, you're not on the edge.
