will lowering my truck mess with my pinion angle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2005, 07:16 PM
brian12c's Avatar
If I was going to install a flip kit to my truck would this make the pinion angle too much? I haven't ever heard of this happening but thought I'd ask. thanks bf
Old 01-17-2005, 07:51 PM
willys36@aol.com's Avatar
Wiki Edits: 21
As long as you aren't doing anything that will rotate the rear end in any way, thus changing the pinion angel, then just lowering it won't bother that in any way. Lowering blocks, raising blocks, etc. don't cause pinion angle problems.
Here is a review of the goal. The green configurations are fine, the red and orange are NO-NOs!
Old 01-18-2005, 06:51 AM
Wiki Edits: 49
Willys, that's a great graphic to use when we get these questions. I usually send people to the Inland Empire Driveline web site since they have a pretty good driveline setup guide there but this graphic pretty much says it all. Hope you don't mind if I borrow it now and then.
Centerline
Old 01-18-2005, 07:26 AM
Wiki Edits: 21
Go ahead. I plagiarized it from somewhere too!
