will more cooler air help make more horsepower???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2004, 12:42 PM
Robbie's Avatar
Last journal entry: nova
<--------on my nova were i got the hood cut out to clear my stacks when i close it,i was wondering ,jegs sells a plate that goes under the air cleaners with a thick peace of foam going all the way around the edge of the plate,and when you close the hood, the foam seals on the bottom of the hood,and the only air getting to the carbs is threw the hood scoop. would this help with horsepower??
Robbie
Old 05-27-2004, 12:48 PM
Tim240Z's Avatar
Well....depends how much influence the hot underhood air is having on your intake charge. I would imagine that with you configuration, there is not much influence.
The bottom line is: It certainly won't hurt. It will keep your carbys cooler.....
Cooler air=denser air=more oxygen=more HP. If there is a significant effect, you may have to retune your mixtures as it could lean it out slightly....
Tim
Old 05-28-2004, 01:53 PM
Robbie's Avatar
anybody else???
Old 05-28-2004, 04:40 PM
Last journal entry: IT&quot;S IN!
I agree i don't know if it will make you huge horsepower gains but it is with out a doubt better.
Old 05-28-2004, 07:07 PM
camaroman7d's Avatar
Yes cooler air will "allow" you to make more power. In order to take advantage of the cooler air you need to adjust your fuel mixture accordingly. You are not going to gain 50HP if that's what you're wondering. In a drag race application we are talking "maybe" a tenth or two depending on the setup. If your engine compartment traps a lot of heat you will see more gains from the cooler/fresh air (with the crab tray/seal you are talking about).
Royce
Old 05-29-2004, 01:50 PM
Robbie's Avatar
thankyou
