Will moving springs inboard cause poor handling?
I've been thinking (after working on the mini tubs) of moving the leaf springs inboard 1/2" to give me adequate clearance for the larger tires I want.
I know 1/2" doesn't sound like a lot, but I can do this without moving the rear frame. I'll have to notch the front leaf spring mounting point on the frame. The rear (shackle mount) just has a cylinder welded through the frame channel. It projects 3/4" on either side. I figure I can just cut it (1/2" off), and extend the inside. Probably gusset it there. I'll have to also redo the spring perches on the axle. Anyway, do you think this will impact handling much? I know narrowing the rear for massive tires, can create a teeter - totter effect, so most go with a 4 link, or custom coilover. Will losing 1/2" creat havoc in the car's suspension? |
Don't worry about it! You'll lose a little rear roll stiffness, which means the car will push a bit more in the corners, but, if you can notice the difference, someone should be paying you big bucks to drive their NEXTEL Cup car.
| mouse smell | swvalcon | Interior | 18 | 03-14-2012 07:11 AM |
| Consequences of wrong springs on my heads? | TVR383 | Engine | 6 | 11-23-2005 10:25 PM |
| Diffrent Springs? | strikingthematch | Engine | 3 | 12-09-2004 09:12 PM |
| Valve Springs | GearHead69 | Engine | 5 | 07-19-2003 11:00 AM |
| moving nova springs inboard | La Maquina | Transmission - Rearend | 1 | 04-09-2003 05:54 PM |
