Will my 700r4 hold? - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Will my 700R4 hold?
Yes 5 55.56%
Possible 2 22.22%
NO! 2 22.22%
Multiple Choice Poll. Voters: 9. You may not vote on this poll
Closed Thread
Old 02-09-2006, 02:00 PM
Will my 700r4 hold?
I have just built a 355 chevy, with an all forged bottom end, flat top pistons (10.75:1), pro lightning 220CC heads, 268-H Comp cam, victor JR intake, 750 Speed Demon, 1956 Chevy 4 door wagon (3400 lbs), 3.55 rearend gears. The trans was rebuilt by a reputable trans shop, but at the time, I just had a crate 350, so did not have anything really special done to it. I plan on getting a trans cooler ASAP obviously, but is it possible the trans will hold it? Thanks in advance.
Kyle
Quick reply to this message
Old 02-09-2006, 04:08 PM
Kyle
It should , your intake don't start making power till about 4000 rpm, and your carb is too big. So I would think it will be mighty sluggish on bottom end.
JMO
Old 02-09-2006, 09:41 PM
dgcantrellsr,
I now only have a 600 CFM EDL carb, and I forgot to mention I have 1.6 rollers. How much power do you think that it might even have?
Old 02-10-2006, 12:19 AM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Well, are you just going to cruise and punch it out on occasion or will you be hitting the dragstrip every weekend?
Either way I would leave it in, it was just rebuilt so it should take some abuse for a while.
Old 02-10-2006, 08:23 AM
dgcantrellsr,
I think the top end of your motor is geared more to the drag aspect , big valves, big runners, high rpm intake, as for power , I don't know , but I do think it ain't gonna have much bottom end ,your cam is 1500-5500 , intake don't start making power to about 4000-4500, Most of the time bigger is not always better. Also it would depend on the converter stall as to the bottom end performance ie HAMMER DOWN ! JMO
Old 02-10-2006, 02:29 PM
This is pretty much how I got the motor. I was planning on doing an RPM air-gap, but can't for the angle of the heads. Also, I do plan on having a cam custom ground for the motor & car, because that cam is going to hold it down alot! Any other suggestions from any of the masterminds in here, also maybe a cam suggestion? I was thinking Comps 280, I don't want to go too radical, probably no more than a 294 or so.
Old 04-04-2006, 10:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I see no further use for this thread to be open........
Closed Thread
700R4 help/advice Mustangsaly Transmission - Rearend 7 12-12-2005 05:54 PM
700r4 tranny in 2nd gen 1980 camaro !HELP! william27103 Transmission - Rearend 10 11-02-2005 07:53 AM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 04:34 AM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 08:59 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
