Will my combo run on 89 octane with no problems? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2005, 05:57 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Will this run on 89 octane with no problems? 10.5 to 1 comp aluminum heads 64cc comb chambers and flat tops. .480 lift 230 @ .050.2900lb car. Runs fine on 92 octane but thats getting very expensive!
Old 03-23-2005, 06:14 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I would try it. The 10.5 :1 doesn't help but the aluminium heads and the somewhat lighter weight of the car will help. You may need to fine tune the timing. Run the tank low, then put a few gallons in. If it knocks too easy top off with a higher octane.
Old 03-23-2005, 06:15 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Not run fine
If your just cruising around the 89 is fine. If you decide to get squirrely you want to have the 92 in there.
max compression ratio on 89 octane gemini86 Engine 31 07-01-2005 03:35 PM
93 Octane / 110 Octane fatrat96 Engine 4 12-29-2004 02:09 PM
Could someone run this combo on their desktop dyno? SmoknR6 Hotrodding Basics 5 10-07-2004 09:51 AM
tuning problems, bad combo?? CurtisL Engine 1 11-01-2003 11:19 AM
Mallory Hi Fire Box problems black66 Electrical 2 08-03-2003 11:55 PM
