Cool thx. What kind of issues do you think I will have with the offset and the u joints? I'm already looking into getting another housing and an alignment jig to make another rearend.
Does anyone know the spicer part number for a 1330 u joint to a ford explorer flange... im trying to find it online and having a hard time... maybe im not looking in the right spot. It appears that ford used different size differential flanges. I measured across the bolt holts and it was just about at 4"... idk if this is the small or large one... I found this.. http://72.236.255.133/p374_1330_seri...ge_bolt_p.html but it says 3"... not sure... help someone lol! Thanks again!
Russ |
![]() There is also Denny's Driveshaft, I've used them before, good parts, and in your area of the country |
Idk if it still matters or not but the measurement from (6 o clock to 9 o clock) is 3" and (6 o clock to 12 o clock) is 4.25" and this is from the inside of one edge to the outside of the other....... is this what i need?................or do i need 2-2-1399? http://www2.dana.com/pdf/J300-P2.pdf Last edited by zildjian4life218; 07-23-2011 at 09:27 PM. |
[QUOTE=zildjian4life218]THANK YOU!!!!!!!!!
Idk if it still matters or not but the measurement from (6 o clock to 9 o clock) is 3" and (6 o clock to 12 o clock) is 4.25" and this is from the inside of one edge to the outside of the other....... is this what i need?................or do i need 2-2-1399? Looks like your correct. You can measure your Pilot Dia to double check. |
From what I have gathered online Ford used two different size flanges for the 8.8 rear end. The referred to them as the small and big flange. I'm guessing tthesmall has the 3.5" bolt circle diameter and uses that 2-2-949 and the big flange uses the 4.25" bolt circle diameter and uses 2-2-1399. Can anyone verify this for me?
| Which Driveshaft? | 31chevy | Transmission - Rearend | 5 | 08-13-2008 09:49 PM |
| Lill Bit Of Body Work And Chassis Work... | h0trod389 | Hotrodding Basics | 7 | 05-23-2007 07:12 AM |
| 700 r4 to 8.8 driveshaft | murrsue | Transmission - Rearend | 12 | 10-23-2006 11:36 PM |
| porting 882s at home,no machine work, rebuild, will it work? what are they capable of | Warrant | Engine | 6 | 12-27-2005 12:14 AM |
| driveshaft | cavkid | Transmission - Rearend | 2 | 04-22-2003 06:09 AM |
