Will my radiator cool a small block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2003, 11:48 AM
New Member
Post Will my radiator cool a small block?
Got a quick question for you guys. I'm building a 34 Chevy P/U street rod. I have a stock 34 chevy 6 cyl. radiator. I plan on adding an electric fan, plastic shroud, and modern style coolant overflow can, along with a modern higher pressure cap. The radiator has been tested at my local radiator shop, and looks OK to them. My question is: will this setup keep my 383 small block cool enough? (It has a 4-speed) How about if I add (the wife wants) A/C?
Anybody out there got any experience with these old radiators?
Thanks!!
Old 01-23-2003, 12:08 PM
Post
I have never had a 34 Chevrolet Pickup but I would guess NO. When new, the radiator was designed to cool around 200 cubic inches with a compression ratio of less than 8 to 1.
Now, almost 70 years later..... you want it to cool almost twice the engine with more compression?
Go ahead and get a new radiator (street rod type) for it. The $500 or so you spent today could save you a 383 rebuild later on.
If you had a 283 Chevrolet.....I would say YES.
Old 01-23-2003, 12:26 PM
el el is offline
Post
those old honey comb rads barely cooled the original engine.it would never cool a 383.
Old 01-23-2003, 12:53 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I used a '36 Plymouth honeycomb radiator to cool my 354 hemi in my Willys for years ~25,000 miles. Just recently had it re-cored with a modern finned core but can't seem to tell a differnce in cooling ability.
My recommendation is try it. If it works, fine, if not, pull it out and have it re-cored. No large thing.
Old 01-23-2003, 03:03 PM
48Man's Avatar
Post
Willis 36,
Did you rod have A/C? <img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
