will my trw 350 pistons work in my 383 project - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2008, 06:50 PM
I just recently purchased a set of trw forged pistons 350..030 ,they have a slight dish and claim to give 9.7 with 64 cc heads, since buying them I came across a great deal on a 400 crank and heard I may be able to still use these pistons..does anyone know if I will have clearance issues with these pistons or with my solid lifter camshaft which is not too radical at all with my rods anywhere???? also if anyone needs a alky carb I have a 750 for 200.00 or will trade for parts I still need.
Thanks to all !
Old 09-03-2008, 07:35 PM
ok ..but!
I know the stock 400 rods are weaker than the 350 rods and I thought I heard of the block being decked in order to use the 350 rods and pistons, I would rather sell my trw pistons than go to a weaker rod...Is there a way to use the 350 pistons and 350 rods with the 400 crank or am I just dreaming????
Old 09-03-2008, 07:57 PM
First off has the 400 crank been ground for the 350 mains?
Thanks to all !
Old 09-03-2008, 09:48 PM
not yet..but I knew I would have to have it turned down to 350 size and have the block ground down by the pan rail area for clearance and I heard they had a special rod bolt with a smaller head to use for better clearance that I planned on buying...
Old 09-04-2008, 09:32 AM
The 400 rod is weaker, But in a street application under 6500rpm they are fine. stock 5.7 rod is good to 7500 or so with a 3.75 crank. I know this from years of destructive testing otherwise known as dirt track racing with claimer engines.
Old 09-05-2008, 10:45 AM
thanks to all for the advice
Well, I don't know what I am going to do now..I did find a 400 4 bolt block for 100.00 and am going to buy it tonight, I do have the 350 4 bolt block 350 crank and trw pistons and pink rods , I always heard the 400 block had overheating problems and I thought that was why people starting making the 383 years ago to start with, If the 400 rod is only good to 6000 rpm...I would call that weaker,not just shorter.. and I appreciate everybodys help and advice here..one thing for sure ,just because something is a good price does not mean it is right for me...Here is a question for you all...If I took the money I would be spending to turn the crank and clearance the block for the 383 and just put that money in the 355 instead would I be happier??? I would still have my 400 block and crank to possibly build a 406 at another time...what do you think????
Old 09-05-2008, 04:36 PM
Well if I was you I would just build a 355 and be done with it. The only real difference that is important wise is that a 383 will give an average of 30 more pounds of torque and the power band if slightly different then a 350. The horse power number will only be different by about 10 or less nothing big to me. I did have a 383 stroker before my current 350 build and I only noticed slight differences in output.
My previous build was a 383 4 bolt 9:8to 1 with 400 crank and rods. The same pistons you have and a set of Dart iron eagle 200cc ported heads and a crane energizer 302h cam flat tappet with a dual plane intake by weiand. I switched the intake to a edelbrock rpm performer with a crane powermax hydraullic roller cam and went back to a 350 with the same heads and had them milled down for more compressiona and now sit around 9:4 to 1 and it shreds the tires on my s-10 and will still throw you back in the seat.
You can build a 383 and a 350 really well both ways just a little bit difference in torque and power band wise between the two. If I am wrong somebody help me out here.
Eric
Old 09-05-2008, 05:27 PM
[Thank you all for your help and advice....I spent much of the day thinking about it and then read some of your replies here tonight also and I am going to build the 355 and put the 400 block and crank to the side for the time being while keeping my eye out on e-bay and other bulletin boards for a good used set of 406 pistons and worked rods at a good price for the future...I just heard about a 72 monte carlo 350/300 horse 12 bolt that was sold for scrap to settle a estate here...I know the guy that bought it and am going to look at soon, I will fill everyone in on whether or not I get it and include a few pic's,hope everybody has a good weekend!
350 Pistons? 67camarokid Engine 3 05-28-2006 07:23 PM
350 rebuilt to 383 question jtswilson Engine 17 03-02-2006 10:54 AM
350 or 383 in 89 camero jackfrost51 Engine 2 02-04-2003 09:16 PM
What is the Best cam for a 383 Strker with Domed Pistons 67' BoleroCam Engine 4 12-05-2002 02:37 PM
350 to a 383 chevellesrule71 Engine 2 10-25-2002 05:01 PM
