Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-21-2008, 02:52 PM
rrsc rrsc is offline
Will not run
I had to pull head off 94 G30 chevy van for alternator bolt broke in head. Got all back together and it will not start. I did check the firing order and tdc all the same time. Some time it will spit and spudder when i hold my foot to the floor. So i am at the end of the rope Help.
Old 05-21-2008, 03:22 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is online now
Moderator
 T-bucket23's barnstar
re: Will not run
You most likely have the distributor in wrong or it is just a bit out of time.
1 Pull the # 1 spark plug.
2 Put finger over hole and have someone bump the key.
3 When you feel it trying to blow out your finger, bring the timing marks up to
TDC or 0 depending on how it is marked
4 Find the number one wire on the cap and mark its location on the
distributor housing
5 Remove distributor cap, the rotor should be pointing at your mark you made
for the #1 wire
6 If not pull the distributor and get it lined up
It should be close enough to get it to start and adjust the timing at this point. You may need to play with the distributor while cranking to get it to fire.
Chet
Old 05-21-2008, 03:39 PM
wil not run
just one question how do i get step 3 and 4 same time.
Old 05-21-2008, 04:08 PM
T-bucket23's Avatar
Moderator
re: Will not run
I dont understand what you are asking, step 3 is getting the timing mark on the damper lined up and 4 is marking the distributor before you pull the cap
Old 05-21-2008, 05:01 PM
jdshort98 jdshort98 is offline
re: Will not run
I think he means holding his finger over the hole while cranking the engine!
Old 05-21-2008, 05:12 PM
will not start
I have done all of the above. I have pulled the spark plug out i can turn motor and cover the #1 plug at the same time. I have checked the morm. balance with my mark and move the dist. to the sparkplug wire to #1 spot. Other then taking my 50 caliber rifle and shot it i am lost to this point.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Will not run"
wire me up tbelltim Electrical 1 05-18-2007 01:07 AM
HELP , My Firebird is dead IGENFIREBIRD Electrical 29 04-23-2007 02:24 PM
how to build 454 to run propane with 600+HP? propaine rockcrawler Engine 0 03-04-2007 09:12 AM
how to run heat riser tubes? matt167 Engine 1 09-12-2006 04:49 PM
Engine and tranny run in Wheels427 Engine 6 03-16-2004 07:34 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
