will not start - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 03:33 PM
b01j05s08's Avatar
will not start
ok i have buick van 2005 and i have alot of work done to it and no one can find out what wrong with if u live it for more then 13 hours and try to start it will not start we have had it about a yr now and it way to get where i need to go i have 4 shop look and no one know what going on someone help me plz
Old 04-21-2011, 05:27 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
So it cranks over and does not start? If it sets overnight it wont start? How do you get it to start?
Please answer , need more info.
Old 04-21-2011, 06:12 PM
b01j05s08's Avatar
i have ti jump it of to get it started the next time
Old 04-21-2011, 06:23 PM
LATECH's Avatar
so then the battery goes dead and you have to jump it?Otherwise it will startOK if jumped?
Old 04-21-2011, 06:28 PM
b01j05s08's Avatar
yes it start ok when u jump it off its a new battery i just trying to find out why it keep going to dead???
Old 04-21-2011, 06:33 PM
el pollo's Avatar
It's shady under this tree...
When it doesn't start, is there power to anything else? As in the interior lights, radio, etc?
Old 04-21-2011, 06:39 PM
b01j05s08's Avatar
ok when u just let it set for more then 10 hours and nothing will work i have to use the key to open and everything and there some time it take a long time to get it to jump off its bee going on for 2 mos now
Old 04-21-2011, 06:44 PM
LATECH's Avatar
You have an electrical issue then OK. Something is discharging the battery.
I got it.
a good mechanic should be able to chase that down in under an hour.
Old 04-21-2011, 06:46 PM
b01j05s08's Avatar
where that????
Old 04-21-2011, 06:48 PM
LATECH's Avatar
The alternator could be running the battery down when the car is off, several other things can run the battery down when the key is off also.
Radio memory circuitry can kill the battery.a hidden light that is on can kill the battery ,like an underhood light that is faulty and doesnt turn off, or a glovebox light.I had a few cars that the oil pressure switch was staying on and running the fuel pump after the car was off...killing the battery.
Old 04-21-2011, 06:54 PM
b01j05s08's Avatar
ok it dont the light i have the thing makes everything go off we have made sure thats it not the light the funny thing about it is it start doing after we jumped a other car off and we had a radio put in
Old 04-21-2011, 07:05 PM
LATECH's Avatar
I would suspect the radio is the trouble. The alternator could be the problem also as they can become damaged when you jump start another vehicle. I personally dont give people jump starts for that reason.
At least you may have it narrowed down to 2 different things.
you could disconnect the radio and charge up the battery, then see if it stays up overnight.then you would know.
Old 04-21-2011, 07:07 PM
b01j05s08's Avatar
thank i will try that and see what i get from it thank u so much
Old 04-22-2011, 03:56 AM
EOD Guy's Avatar
With that new radio, did you put in a new amp? Just had a friend that put in a new amp and they were defective drained his batt overnight.... as suggested disconnect the radio/amp see if it still goes flat.
Old 04-22-2011, 05:15 AM
willowbilly3's Avatar
Last journal entry: Body mods
You can easily test for a drain by disconnecting the negative battery cable and inserting a test light. It will light up if there is a drain. Then you methodically start disconnecting things that might be suspect. Best to start by pulling fuses one at a time.
I highly suspect the sound system too. When I had electrical issues come to my shop, the first thing you look at is the aftermarket stuff. Stereos, trailer wiring, almost always the issue. Who installed the system? One of the same 4 shops that don't know how to check a system for drain?
sbc 350 will start run rough for a few seconds die and wont start fuel-junky Engine 11 01-08-2013 11:30 AM
'51 235 no start matt167 Engine 14 06-04-2009 07:21 AM
Easy cold start, hard hot start dedub Engine 34 08-13-2008 05:21 PM
change modular car will start shut off and won't start back up Ramman Engine 1 11-26-2004 08:20 PM
Tpi start up Chevy Thunder2 Engine 6 06-09-2004 11:03 AM
