-   -   Will oil pan seal with one broken oil pan bolt? (http://www.hotrodders.com/forum/will-oil-pan-seal-one-broken-oil-pan-bolt-194232.html)
Dougie 03-10-2011 06:48 PM
I know this topic has been covered, but I did a search and can't find an answer specific to my question. I have a SBC with one oil pan bolt in center of one long side that has a broken easy out, and I've given up trying to get it out. This is a budget build, mild 327. I have a new stock steel oil pan that I will be using. If I bridge the broken bolt hole with a reinforcment plate made of, say 3/16" steel, that fits on top of the pan rail, will this be enough to keep it from leaking? Any other thoughts? Thanks.
poncho62 03-10-2011 06:52 PM
It should be fine...Personally, I dont even think you have to make that strap
oldbogie 03-10-2011 08:29 PM
It should be OK. It it weeps you can get the hold down clamps used for rocker cover leaks, trim a couple to fit and use the good adjacent bolts to clamp some reinforcement over the broken bolt area.
Bogie
