Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-10-2005, 08:17 PM
daveh daveh is offline
Will An Olds 455 Engine Fit In My 69 Firebird
Hey guys,
I just bought what I thought was a pontiac 455 for my 69 Firebird but what I got was a 455 oldsmobile engine. I know I should have done my research. Anyway I got it and my question is will it fit ok? Do I have to make any unusual modifications? Any help on what to do is appreciated. Thanks
Dave
Old 11-10-2005, 08:27 PM
woodz428's Avatar
woodz428 woodz428 is offline
re: Will An Olds 455 Engine Fit In My 69 Firebird
Unless you have a bell housing for the Olds pattern, that will need changing. I think that the 403 Olds engine (called a corporate engine at the time) was available in some mid to late '70s 'birds, so you should be able to get motor mounts and other parts to set it right in.
Old 11-10-2005, 08:28 PM
techinspector1 techinspector1 is offline
Senior Curmudgeon
 techinspector1's barnstar
Wiki Edits: 114
My son and I put a 455 Olds in a 72 Luv truck for his high school driver, but I've never put one into a Gen1 Firebird. Here's some info I came across, hope it will help....
http://www.442.com/oldsfaq/ofswp.ht...gine%20Swapping
Old 11-10-2005, 08:36 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
The subframes on the post 69 Camaro/Firebirds are front steer like the Chevelle and GtO frames. So you may have to fabricate frame mounts for the early rear steer frame. A 455 Olds will fit. As mentioned you will need an Olds compatible trans but any BOP 350/400 turbo should fit. exhaust manifolds or headers might be tuff to find also. As the steering box gets in the way.
I have done 500 Caddys in this combination with nearly all factory parts.
Old 11-10-2005, 10:12 PM
Senior Curmudgeon
Wiki Edits: 114
"As the steering box gets in the way."
Of course it'll make it tougher to fit passenger side exhaust, but you can move the motor/trans to the passenger side slightly to get some clearance if you need to, just be careful about keeping the centerline of the crank parallel with the centerline of the car to prevent u-joint problems.
On a 302 Ford / 83 Mitsubishi truck swap i did, I moved the motor-trans to the passenger side of the truck 2 1/4" to clear the box.
Old 11-11-2005, 01:38 AM
jimfulco jimfulco is offline
The subframe of the '67-'69 Firebird is basically the same as the '73-74 Olds Omega, which, I believe, was available with an Olds 350 engine. The motor mount position on the Olds 350 is at the same place as on an Olds 455, so you may be able to use the mount system from an Omega with an Olds 350 to mount the Olds 455 in the Firebird subframe.
The '69 Firebird used a metal frame bracket with a rubber & metal mount sandwiched between it and the engine. On the Omega, a solid metal bracket was attached to the engine, and a rubber & metal "clamshell" mount went between the frame & that bracket. The bolt holes in your frame might not be in the right position, but you can drill your own if you need to.
The 455 has a taller deck than the 350, so accessory brackets from the 350 probably won't fit the 455, and you might run into some interference since the 455 is a little wider. It might be easier to just sell the Olds 455 or see if you can find someone with a Pontiac 455 that's willing to swap.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Will An Olds 455 Engine Fit In My 69 Firebird"
455 buick and olds Motor mount Question TransAmRob Engine 4 11-28-2004 06:06 PM
timing spec for 73 olds 455 stock engine Cutlass327 Engine 2 04-27-2004 04:46 PM
Olds 455 Gundarak Engine 44 03-12-2004 08:21 AM
455 olds engine..hot number 57chevymike Engine 8 11-26-2003 05:57 PM
will a 1969 455ci olds engine bolt right in place of a pontiac 400??? chevyelc81 Engine 3 06-12-2002 03:54 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
