will only go into reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2012, 12:25 PM
I have a turbo 350 behind a 350 v-8 in my 34 Pontiac. I don;t know what it came out of but it only has reverse and won't go into park. There is some kind of a diaphragm located at rear of tranny on pass. side. So before I pull tranny I would like to know what is it for??
Old 03-02-2012, 02:29 PM
rick 427's Avatar
Last journal entry: The Cheetah
does the shifter go thru all the other ranges??
Old 03-02-2012, 04:10 PM
No....tranny will not go into any other gear.....I also just noticed that vac. line from modulator to intake has a big hole.....will that affect it?
Old 03-02-2012, 04:16 PM
rick 427's Avatar
no and yes...but thats a different scenerio.....but if your shifter won't shift thru the ranges.....disconnect it at the trans,and try shifting it by hand at the trans,and see if it goes thru the ranges that way....and check back
Old 03-02-2012, 08:37 PM
Yea I did that already.
Old 03-02-2012, 08:43 PM
rick 427's Avatar
ok... .. and did it shift into all the ranges???....or was it binding when you tried to turn the selector on the trans?
Old 03-02-2012, 11:03 PM
I disconnected linkage at trans and it still won't go beyond reverse. When I first installed tranny I had everything except park. The car has never been on the road with this tranny installed (am getting near the finish line on a five year build on the 34) Discovered today that vac. modulator line had a hole in it...will repair tomorrow.
Old 03-02-2012, 11:13 PM
rick 427's Avatar
To get the linkage working you're gonna have to pull the pan...pull the filter..and look at the inside linkage lever next to where it goes thru the trans...you will most likely see a backed out 5/16 bolt that is stopping your linkage from working....rotate the linkage,you'll see it hitting the head of the bolt....grab a 1/2'' wrench and screw it back in and snug it up.
Old 03-06-2012, 05:28 PM
350 trans
That sounds like a good plan...will try it tomorrow....thks.
T-400 Reverse problems, slips & then no reverse Kidplunge Transmission - Rearend 1 03-14-2011 08:17 PM
th-350 only reverse 85-monte Transmission - Rearend 4 10-12-2008 11:37 AM
Car Will Not Go Into Reverse?? HotRodMan Transmission - Rearend 15 05-22-2007 02:33 PM
No Reverse! Neophyte Transmission - Rearend 2 12-23-2006 09:26 PM
no reverse!!!! gmsilveradonm Transmission - Rearend 4 01-04-2004 03:32 PM
