will original shocks work with a dropped front I beam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2006, 01:14 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
if i put a 4" dropped I beam in a 37 ford will the front shocks still work? or does this effect their range of motion some how? thanks bob
Old 01-08-2006, 12:02 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Bob,
As long as the shocks are still with in their "throw" area{ compressed ~ fully extended} there shoulden't be any problem.
SR66
"SlowRide66"
"Illegitimis non carborundum"
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 09:42 PM
front end work question and help needed 49olds Suspension - Brakes - Steering 4 08-23-2004 07:54 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 05:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 07:50 PM
Front suspension Vapor Suspension - Brakes - Steering 7 02-03-2002 06:28 AM
