Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will paint peel if I only paint firewall? Should I wait to paint whole cab?
Old 07-04-2012, 05:50 AM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
Originally Posted by jsm1847 View Post
Pulled my motor, had it rebuilt, ready to drop back in. What is holding me back is I'm painting the truck a different color. I can access the firewall much better with engine out. But I'm ready to put motor back in, but not ready to paint cab. Should I...
Paint firewall without painting cab? I could tape it off with no problems hiding tape line.
Or wait until I shoot the cab and firewall all together?
I have been a little worried about the clear coat edge peeling.
Personally i would do it while you have the engine out. I would not have been able to spray the firewall on my 67 as the rear of the engine is too close to the firewall. I dont know how much room you have, but i just taped my engine bay separating the top cowl. I had a drip rail separating the engine bay from the cowl. You may not have this .?? If you dont have a point of separation then you will just blend the two making sure to prep the overlap when you spray out the top.
