will a paxton SN93 supercharger fit my 351w? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2005, 07:47 AM
Fordy8man's Avatar
ive got a 351w from a 80's crown vic police cruiser in my hot rod. its got the variable venturi carb on it. will the SN93 supercharger that i have fit on it. can it be used with the vv carb or would i have to get a new carb. i have only the supercharger no other parts to it. what do i need to hook this up. i can make all the stuff its just finding out what i need to make. ive seen the mounting bracket for one of these and it has other pullies on it. if i build my own bracket do i need them or can i go straight from the motor pully to the supercharger. i will take any kind of info that i can get. thanks Tim
Old 04-02-2005, 08:13 AM
its not my fault
i think you would want to. lol, the VV and the EFBC are ford nighmares.
Old 04-03-2005, 12:00 AM
For the love of God! get rid of the vv carb! As a former dealership tech. I only have BAD thinds to say about them. Sometimes you can find one that's not crapped out. But you'd be better off with a Carter AFB or the Edelbrock knockoff of the AFB. If the Paxton setup is similar to the Vortec, then you'll have to have idler and tensioner pulleys if you fabricate your own bracket. I'd check around some swap meets for a bracket first. Or , at the very least, Check if Paxton has a web site and get as much info about your supercharger as you can. Another recommendation would be; provided you can afford it, Instead of a carb. Get a Holley TBI kit. Or an aftermarket TPI system to go with the Paxton. That way you can program your own fuel map. I'd also go with a prgrammable ignition box like an MSD. That way you can have finer tuning of your fuel and spark timing needs to go with the boost. Sorry this is becoming a book. Hope it helped. -mike
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
