Will Performer RPM heads be OK on my SBC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2008, 04:38 AM
v8hed's Avatar
AK427
SpeedPro H618CP (domed, 3.5cc) pistons, 0.025" deck clearance. Will Performer RPM heads be OK (ie. sufficient piston-to-valve clearance)? Would be installing with Felpro 1094 shim gaskets for 10.7:1 CR and 0.040" quench. Cam is Performer RPM.
Thanks,
Ian.
Old 06-20-2008, 05:58 AM
GaryNova's Avatar
With a deck of 0.025 and a 1094 head gasket with 0.040 that's 0.065 so I say it is looking real good.The cam will have a lot to do with it but as I see it you can use about any cam with that.I have run a 383 small block with track 1 heads cut 0.100 and a 0 deck and a 12.5:1 200 dome with a 1094 and not hit with a 0.630 lift roller cam with 1.6 rockers.With a Dur. of 260 to 270 at 0.050 most pistons are cut to handle over 600 lift cams but the Dur. will have a lot to do with how long the valves are open at just before top dead center and just after top dead center.
Old 06-20-2008, 06:26 AM
v8hed's Avatar
AK427
Thanks guys. The original (pro) engine builder also advised me to definitely not use the shim gasket with ally heads.
Cheers,
Ian.
Old 06-20-2008, 10:49 PM
GM makes a .028" composition gasket that they say is OK with aluminum heads. PN is 10105117
http://www.sdparts.com/product/10105...eadGasket.aspx
Old 06-21-2008, 09:39 AM
Just order a set from Cometic. Custom I think you can get down to .022" IMO a high quality head gasket is worth the investment.
I am not a compensated endorser/agent of any known product.
SBC Heads -= AFR - Trickflow - Dart - Brodix =- Delirious2000 Engine 25 04-22-2009 12:58 PM
need info on Edelbrock rpm performer and.. ryork Engine 4 09-22-2007 04:23 AM
head ache. sbc heads excaliberprime Engine 7 03-07-2007 06:03 PM
'76 400 SBC cracked heads 87Camaro Engine 5 04-19-2004 11:01 AM
bowtie heads for sbc Eddie Baker Engine 3 11-08-2003 11:02 PM
