Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will Rear Disc's Stop Better Than Rear Drums??
  #42 (permalink)
Old 01-17-2006, 10:05 PM
Triaged Triaged is offline
IIRC the larger (7/8") wheel cylinders were about $5 each for new ones. When you have it apart you might as well spend another $12 and put new shoes on it.
I used them to balance out the 12" discs I put in up front and they worked great even with the stock prop valve.
As for master cylinders there is no difference between disc/drum and disc/disc except maybe bore and the size of the reservoirs.
