Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will Rear Disc's Stop Better Than Rear Drums??
  #43 (permalink)
Old 01-18-2006, 09:17 AM
xautoracer xautoracer is offline
Master Cylinder
Originally Posted by Moon
One possible problem I might have is the master cyl is a disc/disc and I have a disc/drum. I don't know if the internals are different than a disc/drum. Guess I'll have to call one of the brake vendors and ask the tech dept
Moon
What you're missing is the residual pressure check valve....I don't know if you can put one in a disc/disc master cylinder....I've removed them from drum/drum master cylinders to make front discs work better....I suggest you get an A/G body master cylinder and hook it up just like the service manual for a Monte Carlo or Malibu tells you....Then you'll have a built-in residual pressure check valve that you need for your rear brakes....
