Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - will this rear end hold together?
Old 03-27-2005, 07:58 PM
ko.17 ko.17 is offline
i've been searching past posts to see if anyone has broken a rear end or axle because they had too much power. found one post but didn't really see much that would apply to my setup. the engine will make 400 plus hp when finished and the car is a 76' camaro with a 10 bolt posi w/4:10 gears. at point should one consider swapping rear ends to a 12 bolt. i've also been told to watch the body for twisting and rippling. should i be concerned about either the rear end or body?
thanks for your time.
