Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - will this rear end hold together?
Old 03-28-2005, 07:08 AM
astroracer's Avatar
astroracer astroracer is offline
I responded to a similar post about this the other day. Unless you are running big sticky slicks and have enough traction to pull the front tires you really don't have anything to worry about. What breaks and twists things is traction. Putting all of that power to the ground is going to be difficult if you are running a stock rear suspension on street tires. You really have nothing to worry about except maybe tire wear.
Mark
