Will this rear fit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 05:40 PM
Will this rear fit?
The 12 bolt that I have aquired that I was told came from a 70 El camino turned out to be something different.
After spending a few days stripping it, I found the code on the passenger axle tube when I ran the code i discovered that it came out of a 1970 Pontiac GTO/Grand Prix...
I have no idea about dimmensions of this thing but what I want to know is will it fit into a 71 Chevelle, and will there be any sort of parts interferance.
Old 07-07-2005, 07:56 PM
BOBCRMAN@aol.com's Avatar
It SHOULD fit with all factory parts. These cars used basically the same frame/chassis from 68-72. 10-12 bolts of various design were all used.
Old 07-07-2005, 08:41 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
I've read that they will fit...
Old 07-07-2005, 08:53 PM
GothRod87
Yes it will fit ...my uncle has a 69 gto and its the exact same frame and rear end mounts...we blew the guts out of the rear end on sunshine drag way and replaced it with a chevelle rear end..good luck,
Brandon
Old 07-07-2005, 10:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
for some reason this comes to my mind...
Look at the U - joints on the yoke of the differential.
Some where in there ( years?) some GM products used inner U-joint retainer clips on the yokes / drive shafts , some used the outter style clips
Old 07-07-2005, 10:57 PM
Ah that is great news to hear, i just spend nearly a week fixing this thing up and it would have been such a bummer to hear i just spent a nice chunk of change on a usless hunk of metal.
Rear ends... chrisflock Transmission - Rearend 12 06-04-2005 09:05 PM
will nova rear end fit in 67 firebird? red_rider52 Transmission - Rearend 9 01-19-2005 10:52 PM
57 chevy rear disc romine Suspension - Brakes - Steering 2 11-06-2004 05:43 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 07:14 PM
