Will this run on 93 octane? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2006, 09:03 PM
Just wondering....
383 sbc stroker.
5.7 h beam rods.
speed pro pistons.
combustion chamber size is 64.
head gasket thickness is .039, im not sure about the head gasket bore, maybe 4.180? if someone could help me on that too.
piston to deck cleaence i think is 0 or possible .020.
valve releif is 3.40. flat tops.
cam specs: lift .520''/.540'' Duration 282/290.
I cam up with a quench of .039.
and a compression ratio of 11.3:1
Im really not sure if my calculations are right, this is my first time doing this, so pleasure correct me, and also tell me if this will run on 93 octane(maybe a lil octane booster) thanks alot.
Old 12-26-2006, 09:07 PM
O yea....i also got a calculated dynamic compression ratio of 8.9 if that helps any
Old 12-26-2006, 09:52 PM
kuhn-77's Avatar
Build it right the first time
I seriously doubt that 11.3:1 comp will run on pump gas even with octane booster...my 10:1 383 stroker barely runs on 93, i have to keep the timing way off to keep her going with out detonation...which it still does from time to time
Old 12-26-2006, 10:10 PM
Maybe i should run a set of dished piston with about a -12.00 to brin the static compression down to 10.2:1 and a dynamic of 8.1:1.
Old 12-26-2006, 10:12 PM
oops i ment +12.00
Old 12-26-2006, 10:16 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Just wondering....
383 sbc stroker.
5.7 h beam rods.
speed pro pistons.
How did you get those compression numbers? There are too many variables.
1) Octane compatability depends on the chosen chamber shape.
2) Using the variable of your head chamber/bore ratio you have a variation of .4+
3) The head gasket could be a variation of .1+
4) Valve reliefs volume is not the same as piston volume which measures from the rings up.
You need to get some specifics before you make a big mistake.
Octane booster is a marketing joke. The maximum recommended dosage increases octane .8 that's point 8 of ONE octane.
Yes it will run on 93 or even 87. But will it run well? You can crank back the timing to make it run on 87 but power and response will probably suck.
You might look into head grooving.
Singh's Grooves in Ported & Milled vortec heads on stock 350
Remember you can build a 450 hp engine with a fuel problem or a 435 hp engine that will run on 87. Your choice.
kuhn-77's Avatar
that should prolly work nicely with aluminum heads
Old 12-26-2006, 10:31 PM
71C10's Avatar
U.S. Army Retired
You had me until "head grooving" call me a skeptic, but if I were going to "experiment" with grooves it would be in something a bit more disposable, like pistons!
Now I've done it! Here come the flames!!!
Old 12-27-2006, 09:12 PM
xntrik's Avatar
I agree. Skepticism is good.
It is the principle of the grooving that helps. Reducing detonation at lower rpm /high BMEP.
I believe grooves help..... and at worst, can't hurt.
If you get convinced, try them. If not...... don't.
Hey I'm only talking $ 80 year difference in gas prices.
Sorry, did not intend to hijack this.
Will my combo run on 89 octane with no problems? 67 Deuce 4 Me Engine 2 03-23-2005 07:15 PM
What size heads to run on a 455 Scooby333 Engine 3 02-14-2005 07:15 AM
93 Octane / 110 Octane fatrat96 Engine 4 12-29-2004 03:09 PM
Octane!!! NXS Engine 6 12-07-2004 09:53 AM
Octane boost vs. Cam2 78 monte Engine 11 07-26-2002 11:21 PM
