Will same flywheel function on chevy 427 & 454 engines? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2013, 06:21 PM
I am running a 427 truck engine in my model a coupe with a 350 automatic.i am getting ready to put in a 454. My question is will the same flywheel work on both engines.
Old 12-15-2013, 06:37 PM
BOBCRMAN@aol.com's Avatar
It will bolt on but it won't work. 454 needs weighted flywheel/flexplate
Old 12-16-2013, 05:57 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Jester
Old 12-16-2013, 06:10 AM
ProStreetRob's Avatar
5.7L S10 LS SS
I made that mistake once and it wasnt pretty. I took out a normal internally Balanced 350 and installed what I thought was just a different year Junk Yard Motor. SOB turned out to be a 400 externally balanced motor and I used the original Flywheel and HOLY VIBRATION BATMAN IS ALL I CAN SAY
(what could I say it was 30+ years ago and I was young and foolish )
couper
283-427 uses the same flex plate, (except 400)motors are Internally Balanced
454 uses a unique Flex Plate (except Gen V & VI) motor is Externally Balanced
http://www.jegs.com/i/JEGS+Performan...01005/10002/-1
http://www.jegs.com/i/JEGS+Performan...01000/10002/-1
Old 12-16-2013, 08:51 AM
RWENUTS's Avatar
Question for you Prostreet?
What about the 366 and 427 tall deck blocks. Same internally balanced like a 396 or 427 short deck or externally balanced.
Old 12-16-2013, 08:32 PM
5.7L S10 LS SS
Thats a good question and I honestly dont know the answer, only know the ones I've had or had problems with, the 350/400 screw up I experienced and I cracked a few 454 Flex Plates in my old 70 Chevelle SS
I do know those Tall Deck Truck & Bus Motors were pretty cool, I actually bought a big ***** GMC delivery truck @ 35 yrs ago and tried to fist put the BB in my Box Nova (screwed that up ). Then I put it in my 70 SS Camaro and it gave me many miles of tire shredding enjoyment.
Old 12-16-2013, 08:48 PM
Tall deck or short doesn't make a difference. 366 396 402 427 all use neutral balance.
The Following 2 Users Say Thank You to BOBCRMAN@aol.com For This Useful Post:
AutoGear (12-17-2013), RWENUTS (12-16-2013)
Tri star engines 427 sbc fast383 General Rodding Tech 20 02-09-2013 11:28 AM
366 & 427 TD chevy engines m/w Engine 5 03-16-2010 10:03 PM
396/427 Flywheel Question Fastest65 Engine 6 11-05-2008 10:36 PM
What is the differrence between a 427 chevy bb and a 427 chevy tall deck brian12c Engine 11 01-29-2007 10:58 AM
converting a chevy 454 into a 427 Montegogo Engine 2 07-23-2006 09:35 AM
