-   -   Will a short waterpump work on a TPI350 (http://www.hotrodders.com/forum/will-short-waterpump-work-tpi350-172575.html)
upstand2 02-05-2010 05:28 PM
Heres the deal, My uncle has a 34 ford pickup and a 89 iron headed tuned port 350 engine that he wants to put in the truck. He would like to run a short waterpump to conserve space. My other uncle says it won't work because the crankshaft is longer! I really think there's some brotherly love happening here but I thought I'd ask you guys.
1slow64 02-05-2010 07:36 PM
should work fine as long as you get pulleys for a short pump engine.
I am running a corvette(intermediate) pump on my 73 400 truck motor. Using pulleys for a vette.
cobalt327 02-05-2010 08:04 PM
The serpentine set-up will have to go, you'll need all the pulleys and brackets from a SWP set-up, or aftermarket, I believe.
No diff in the crank lengths, but the damper/crank pulleys are different.
THIS thread might give you some ideas on using different pulleys.
upstand2 02-06-2010 07:12 AM
Thanks, this will help.
