will starter bolt up still? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2002, 01:35 PM
rp rp is offline
Post will starter bolt up still?
Have a 1968 327 chev. that had a powerglide bolted to it orig. Now have a rebuilt 350 trans. and need to know if the rebuilt starter I have for the orig. 327/p.g. will have any problems working for the 350 trans.?
Also need to know if the p.g. driveshaft will work for the 350 trans.?
Any suggestions welcome. Thanks! R.P.
Old 05-23-2002, 05:07 PM
Post
both should work fine.the starter tuns the engine over,not the tranny.you might have a problem with drivshaft length.as there are 3 different length 350's that I know of.hope this helps
Old 05-26-2002, 03:03 AM
New Member
Wink
RP If you still have the pg, set them side buy side. And if you have a short tailshaft trans you will see that their is only 5/8'-3/4' differance. Your trans mount will work also, same holes,a direct swap. Did the same thing your doing and she slipped right in! In my 67' nova I did have to get a Lokar flexible dip stick because of tight squeeze in nova. Good luck to ya!
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 21 01-31-2008 10:51 AM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
broken bolt housing on 350 block for the starter bearmacias27 Engine 8 07-13-2007 08:55 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
Starter questions zipfactor Engine 6 08-07-2005 07:10 AM
