will stock drive shaft work with 700r on longbed s10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2007, 05:21 PM
i need to know if my stock drive shaft will work on 700r tran's on my 92 s10 long bed can anybody help
Old 05-23-2007, 07:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
not sure I follow your question.
S-10 came with 700 / 4l60 trannys in them.....
are you changing from manual tranny to a 700 tranny or what?
Old 05-23-2007, 08:00 PM
yeah i'm going from manual to auto i have a 305 with a 700r i just want to know if i have to change drive shaft because it's a long bed
drive shaft removal stu_yoakam Transmission - Rearend 13 04-02-2007 02:01 AM
2-piece drive shaft A35coupe Suspension - Brakes - Steering 3 08-22-2004 06:23 PM
Will stock valve springs work with a comp 268H cam? Mike_82 Engine 7 12-22-2003 03:35 PM
93 gmc cams that will work with stock setup tonyabillyd Engine 0 10-16-2003 10:38 PM
St-10/ 2 piece drive shaft question 85406 Transmission - Rearend 1 04-16-2003 01:36 PM
