Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will stock valve springs work with a comp 268H cam?
Old 12-22-2003, 12:10 PM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
The only way to know is to measure coil bind and spring pressure. In all honesty you are 99% of the time better off replacing the springs and getting the ones that match your cam. This is the only way to get full potential out of the cam. I assume you know you have to replace the lifters as well, right? If not you will ruin your new cam before it is even broken in.
