Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will stock valve springs work with a comp 268H cam?
Old 12-22-2003, 03:20 PM
11echo's Avatar
11echo 11echo is offline
Old Guys Rule!...EVERYTHING!
IF you use stock spring you stand a good chance of floating the valves at high RPM, BUT if you use HI PREF springs it adds extra pressure on the lifters, which can "prang" your cam. IT's one of the pit falls you get into if you just add parts without knowing how they interact with each other, also that's what it's better to get kits with all the stuff from the same manufacture, so everything is made to work together. BELIEVE me, been there, done that!! Good Luck! ...Mark
