Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will stock valve springs work with a comp 268H cam?
Old 12-22-2003, 03:33 PM
Full Throttle Full Throttle is offline
Mike, its been a long time since I was 17 but when I was I put a about the same size cam in my camaro. A lot of stock rocker arms do not have enough slot length to handle a .460 lift cam and will start breaking rocker arm studs over time because of stud deflection. It happened to me and several others I know. Just something else you need to consider. At the minimun you'll need some long slot rockers if the stockers hit.
