Will sway bar work this way? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2012, 08:50 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
I have a 99 Ford Explorer rear end going under my '37 Chevy 4 door. The rear sway bar interferes with the gas tank so I flipped it over. As long as when the weight of the car is on the suspension the sway bar doesn't hit the bottom of the body, is there any reason I cannot mount the sway bar this way and make some attachments to mount to the spring crossmember?
The pictures doesn't show it very well but the first arm of the sway bar comes to about even with the bottom of the frame.
Here's how it looks.
Thanks,
Brandon
Old 04-17-2012, 09:33 PM
Nope, the link will simply pivot up and down and do nothing to the sway bar.
The link needs to be vertical so it pushes down on the bar.
Old 04-20-2012, 09:43 PM
Ideally the end link should be near vertical and
the first sway bar bend horizontal, making a 90 degree
angle between the two.
A few possibilities to think about:
Shorten the end link and mount to the frame.
Rotate the sway bar left to right, and mount the
end link to the frame. (This might reduce ground
clearance, or interfere with the shock...?)
Replace the bar with one from a Ranger or Bronco II?
These have the first bar bend toward the front and the
end link placed more forward, over the frame arch.
Old 05-03-2012, 11:51 AM
Vetteman61's Avatar
Thanks for the tips guys. I wound up having a custom gas tank made so I can mount the sway bar properly as described in this post. I posted pictures of how I mounted it in my photo journal.
Thanks,
Brandon
Sway Bar? Piston1 Suspension - Brakes - Steering 2 09-27-2010 08:54 AM
Sway bar ? buford 8 Suspension - Brakes - Steering 2 03-04-2007 05:25 AM
sway bar nugget Suspension - Brakes - Steering 1 12-14-2005 09:33 PM
sway bar? Echofive Suspension - Brakes - Steering 14 06-16-2004 06:13 PM
Sway Bar low77ride Suspension - Brakes - Steering 7 12-19-2003 07:36 PM
