Will a T-350 drive shaft yoke fit a 200-4r tranny? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2012, 01:58 PM
I have a drive shaft from a THM350. Will that yoke work with a 200r4?
I'm building my own hot rod. I got the drive shaft and rear suspension out of a '75 Jag that had the popular SB350/THM350 swap done to it. I'm using a 200r4 for the hot rod, and if the yoke fits, I can just build my frame to fit the drive shaft as it is. It'll save me a couple hundred bucks I suppose.
Thanks!
Chris
Old 02-08-2012, 02:21 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
yes
powerglide/th350/2004r
Old 02-08-2012, 03:23 PM
Sweet! I was hoping it would.
Thanks for the info!
Chris
Drive shaft yoke replacement boatbob2 Transmission - Rearend 2 04-27-2011 07:53 PM
Drive Shaft Yoke frickenbored Transmission - Rearend 8 04-04-2010 09:25 PM
T-400 to 4L60E swap - yoke & drive shaft? y5e06 Transmission - Rearend 6 11-03-2009 07:47 PM
drive shaft yoke ricks032003 Transmission - Rearend 9 04-01-2008 10:50 AM
How much yoke on the tranny shaft? yragat Transmission - Rearend 4 02-15-2008 07:07 PM
