Will this T56 bolt up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2010, 08:01 PM
Hey guys I have just located a T56 6 speed out of a 94 trans am at a very reasonable $1000.
http://vancouver.en.craigslist.ca/rd...652024970.html
I am building a 383 stroker for my 1980 camaro and I am planning on customizing the car to bolt on a T56. The block is an earlier 2 peice rear seal block 4 bolt main made I believe in 1970. My question is will this T56 (see the link) bolt up to my block? Is there only certain models of the T56 that will bolt up to the earlier blocks?
Thanks,
Keith
Old 03-19-2010, 10:10 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The LT1 & the SBC have the same bell housing.
Rich
Old 03-21-2010, 12:40 PM
Thanks for the reply Rich. So I ended up picking up the transmission and all the rest of the components with it (flywheel, master cylinder, clutch linkage, pedal assembly, shifter, etc.)......... all of this for $900!! Apparently he had like 5 guys call him right after I did and only a couple hours after posting the ad, I think I got a killer deal here. The trans has 200,000km on it but from what I have read these tranny's last a long time and are pretty bulletproof. Anyways I am putting this behind my 383 in my 1980 camaro that came from the factory with a TH350. I know I am going to need a different trans. mount because the mount for the T56 sits further back than the one on the TH350. Does anybody know if there is a company making T56 custom crossmember mounts when converting from a TH350? I would rather buy one that will bolt right in then try to fabricate one.
Thanks for any help here,
Keith
Old 03-21-2010, 12:54 PM
weld up cross members
http://www.summitracing.com/search/?...ember%20&dds=1
Old 03-21-2010, 06:31 PM
ericnova72's Avatar
More for Less Racer
You might also try Kiesler for a crossmember, they do conversion kits for Tremecs and T-56's.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 02:05 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
New 12 bolt rear? strikingthematch Transmission - Rearend 3 07-29-2004 12:41 AM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 05:48 PM
