will a TH-200 hold behind a mild 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2010, 01:33 PM
Wiki Edits: 31
I can't find any TH-350's cheap locally, but have found a few TH-200's. I see listings say they mostly came behind 6cyls and 305's but did come behind a couple 350's.. will 1 hold behind a mild 350 making ~260 HP?
Old 12-18-2010, 01:59 PM
junior stocker's Avatar
This trans is being used by some stock class drag racers; but highly modified of course. You may want to check over on ClassRacer.Com for more info. Butch/junior stocker.
Old 12-18-2010, 02:57 PM
Onefunponcho's Avatar
when modified they hold up to filthy horsepower ......Many of the gran national guys run them with great success. If you leave it stock they are not as strong. In my opinion I think it would hold up to this power level, as long as you dont test it with sticky tire hole shots or heavy load towing. If its just a driver it should be fine
Old 12-18-2010, 03:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
matt167 was asking about a t-200 trans.
The Grand National car guys seem to run the 200-4r trans.
The back end of the gear train is the same between the two transmittins
Old 12-18-2010, 09:40 PM
artsvettes's Avatar
I am running a 2004r in my 77 vette. I have behind a 355 with a zz4 cam and vortec heads. I have gone through the trans dident go to crazy. Hardened stator, 10 vane pump.Increace OD clutch capacity. Shift reprogramer kit from CK Performance
Old 12-19-2010, 01:21 AM
Wiki Edits: 31
cool. then I won't be worried about it then... funny thing is I had a TH-200 in a '81 Impala parts car ( hit/ totaled with 130k miles ). it was a runner with a 267. I bought it because it was supposto be a 305 or 350, and it only cost $75.. after running the numbers, I was so sick of looking at it, that I took it to the scrap yard without getting the engine/ trans
Old 12-19-2010, 11:17 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the item to watch on a t-200 or 200-4r is the end play in the gear train.
The output shaft in each trans will wiggle around a bit with no yoke installed... that is common
Old 12-20-2010, 06:02 AM
SSedan64's Avatar
Donny Wang used to play around with the T200.
Very light & efficient Trans.
http://www.drwtransmission.com/thm_200C.htm
How strong is a t5 behind a mild 350? thirdgenmustangeater Transmission - Rearend 11 10-22-2009 08:08 PM
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
how strong is a m-20 muncie, hold up to a mild 350 and lots of abuse? wimpywade94 Transmission - Rearend 1 08-10-2004 12:54 PM
Help with crate 350, Parts to make it mild! Rance Engine 2 07-11-2003 04:25 PM
What Air Cleaner to buy for a mild 350 LoudMalibu Engine 15 02-03-2003 06:24 PM
