will a th 350 converter fit a pg? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2003, 05:04 PM
bigwildgrin's Avatar
Rooster
Post will a th 350 converter fit a pg?
I seen an ad for Hughes Performances showing a torque converter that fits th 350/400 and powerglides. how can this be? th converters won't swap with powerglides will they?
Old 05-06-2003, 05:33 PM
airworld2's Avatar
Post
yep with fine spline shaft rather than coarse shaft early glide used.
Old 05-07-2003, 05:25 PM
Rooster
Post
more more, give me more!!
what is early? mine is a '69. the only reference to pg I've ever noticed was if it is aluminum or not, but I've never seen a none aluminum pg. how would I know if I had fine or course without the other one to judge it against? assume I'm ignorant about powerglides and sock it to me.
Old 05-07-2003, 06:50 PM
New Member
Post
you have to change the input shaft to a turbo spline and install a stator bushing for the new shaft.Summit,Jegs,coan etc all have the shafts you need...
Old 05-07-2003, 07:12 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
As papadaddio mentioned you need a turbo splined shaft to fit the 350/400 converters.
Also mentioned: there needs to be a bushing in the stator support for the turbo splined shaft.
Another option is the converter needs the bushing added to the internals to provide support and alignment. Then the PG stator does not need a bushing
[ May 07, 2003: Message edited by: Crosley ]</p>
