will these gears fit my chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2011, 11:23 AM
velle307's Avatar
http://tucson.craigslist.org/pts/2194652794.html
hello
i found a set of gears for a reasonable amount and wanted to know if they would fit my chevelle i have a 1968 300 deluxe with a factory ten bolt rear not sure how to tell inches 8.0, 8.5 ??? any and all help is definitely appreciated
thank you very much, Travis
Old 02-18-2011, 12:05 PM
junior stocker's Avatar
It'll be the 8.2 rearend, not as good as the 8.5, and nowhere near a 12 bolt.
Old 02-18-2011, 12:09 PM
big gear head's Avatar
High Performance Rear Ends
No, those gears will not fit your Chevelle. You have the 8.2 10 bolt in your Chevelle and those gears are for the 8.5 10 bolt. They will not interchange.
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 19 10-13-2016 04:14 PM
swapping 2.56 gears to 3.50 gears shmiv Transmission - Rearend 9 05-16-2009 09:18 PM
Tranny gears or rear gears? strummin67 Transmission - Rearend 4 06-12-2006 10:17 AM
Stock rear gears on a '73 Chevelle Malibu? Malibu73 Transmission - Rearend 1 07-21-2005 04:32 PM
