Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will these heads make the power?
Old 12-10-2012, 09:41 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
A very rough estimate of the power you can make based on just those two peak flow numbers and a 10.5:1cr is 474HP. Remember this is very rough and you have to use all the nessessary supporting parts to make it happen. ( right cam, inake big carb, good headers)
Usually thee cheapy heads can use a good clean up from the out of the box form.
